Syncing a PN-60w with inReach.garmin.com
Contacts and Quick Text messages added to an account at inreach.garmin.com need to be Synced to the DeLorme® PN-60w. If you want to post messages to Facebook, Twitter, or your MapShare™ page with your inReach® satellite communicator, you need to set that information up before completing a Sync.
IMPORTANT
The Sync Device dialog requires the DeLorme Send to GPS Plugin. If you have not previously installed the plugin, you will be prompted to do so. Installing the plugin requires you to close your browser. If you have problems with the plugin, see Related Content for troubleshooting steps.
To Sync Account Info
  1. Log in to a user account assigned to an inReach communicator for PN-60w on inreach.garmin.com and make any desired additions or changes on the Contacts, Messages, or Social tabs.
  2. Click Sync.
  3. After the Sync completes verify the changes made to the inreach.garmin.com account are reflected on the PN-60w.
    Note: The Sync function on the inreach.garmin.com website is unidirectional. Changes made on the PN-60w will not be sent back to the inreach.garmin.com account.
Related
