Creating a Route on a GPSMAP 60/60CS
A route gives you straight-line directions from one point to another, or from one point to several others.
Creating a Route on a GPSMAP® 60 or GPSMAP® 60CS Outdoor Handheld
- Pres the Menu button twice to go to the Main Menu.
- Make sure Routes is highlighted and press Enter, press Enter again to create a new route.
- Highlight <Select Next Point> and press Enter to add a point to your route. The Find Page appears.
- Find a waypoint or other point to add to your route. When you have found a point, select Use from the Point Information Page to add the point to your route.
- Repeat steps 3 and 4 to add more points to your route. When you are finished adding points, highlight Navigate and press Enter to begin using the route.
