Pairing the G2/G3 Dog Training Collars to the Handheld Units
Before you pair the handheld to a G2®/G3® collar, ensure the following:
- Both handheld and dog collar are fully charged
- Dog collar is on and flashing green
- Dog collar device toggle switch, if required, is set to the correct color or position1
To pair the G2/G3 systems:
- On the handheld, turn the dial to a number
- Hold or place the handheld and collar shoulder width apart
- Hold down the power on the dog collar device and the continuous stimulation button on the handheld for 10 seconds.
The collar will beep initially when holding down power, after approximately 5 seconds of holding both buttons they will double beep and the receiver and transmitter are now paired.
If you hear a long beep at the end of the 10 seconds they did not pair correctly.
1 On the Classic 70 and Trashbreaker™ G2/G3 ensure the toggle is up or down as required. You will need to press the appropriate colored button that you want to pair to.
