Getting Started With Fltplan Go
FltPlan® Go Flight planning services, the application that works in conjunction with FltPlan.com, is available on iOS (iPad/iPhone) and Android. Simply go to the iOS App Store, or the Google Play Store, type "FltPlan Go" in the search box, and download the application.
  • FltPlan Go is free and can be downloaded on an unlimited number of devices.
  • Information across multiple devices can be synced with FltPlan.com, so long as the same login information is used, and you are within range of Wi-Fi.
  • FltPlan Go can be used while offline. Downloading charts, updating weather, filing a flight plan, and some other features require an internet connection. However, once the charts are downloaded and flight plan filed, these mapping features work offline for inflight use.
  • FltPlan Go for iPad requires iOS 12 and later to install. FltPlan Go for Android requires OS 6.0 and later to install.  For capacity, we recommend 128GB and a Wi-Fi + Cellular model. If you get a Wi-Fi only model, you will need an external GPS/ADS-B device.
To stay signed in, tap the Sign In button in the top right corner on the FltPlan.com, Maps, or NavLogs tab. Enter your Username and Password, then tap Sign In.
Related
