Failed to Read Server Response Error When Using inReach Sync
When syncing an inReach® device via the inReach Sync desktop app, you may encounter the following error if there is an underlying issue with the network connection:
inReach Sync is not intended to be used with mobile broadband (such as MiFi, AirCard, or cell phone tethering), satellite, fixed wireless, or dial-up Internet connections. If applicable, disable any VPN (Virtual Private Network) that is in use. If this is not possible, use a different computer and/or network connection.
If you continue to receive the error message, uninstall inReach Sync and its associated files with the instructions below, then download the program again from the Plans & Devices tab under the Sync & Update button of the Garmin Explore™ website.
Uninstalling inReach Sync and Its Associated Files
Follow the steps below for your operating system.
Windows
Windows Vista/7
  1. Click on Start.
  2. Select Control Panel.
  3. Select Uninstall a program.
  4. Find the application called inReach Sync.
  5. Select Uninstall.
  6. Delete any .exe files for inReach Sync from your Downloads folder.
  7. Restart the computer.
Windows 8.1
  1. Right-click on the Start menu.
  2. Select Apps & Features.
  3. Find the application called inReach Sync.
  4. Select Uninstall.
  5. Delete any .exe files for inReach Sync from your Downloads folder.
  6. Restart the computer.
Windows 10
  1. Select Start.
  2. Find the application called inReach Sync.
  3. Right-click (or press and hold) on inReach Sync, then select Uninstall.
  4. Delete any .exe files for inReach Sync from your Downloads folder.
  5. Restart the computer.
Windows 11
  1. Select Start.
  2. Select All Apps.
  4. Right-click (or press and hold) on inReach Sync, then select Uninstall.
Mac
  1. Open the Finder.
  2. In the Go menu select Applications.
  3. Find inReach Sync.
  4. Click and drag inReach Sync to the Trash.
  5. Delete any .dmg files for inReach Sync from your Downloads folder.
  6. Empty the Trash.
    IMPORTANT: This must be completed before the next step.
  8. Remove all data within keychain for Garmin.
Reinstalling inReach Sync
inReach Sync for Windows
Current Version of inReach Sync for Windows: 1.4.47.4776
Installing inReach Sync for Windows
  1. Sign in at explore.garmin.com.
    Sign In for Garmin Explore Website
  2. Select PLANS & DEVICES.
  3. Select Sync & Update.
    Sync and Update Page on Garmin Explore Website
  4. Select Windows or Mac to start the download.
    NOTE: Either Windows or Mac link can be used as they will download the same file.
    If you encounter an error while installing inReach Sync, uninstall any older versions of the Sync application, then try again.
    inReach Sync Windows or Mac Hyperlink
  5. Locate the download on your computer and open it.
    Google Chrome Instructions
    1. If prompted, choose where you want to save the file, then click Save.
    2. When the download finishes, you will see it at the bottom of your Chrome window. Click the file name to open it.
      inReach Sync Download in Google Chrome
    Mozilla Firefox Instructions
    1. When prompted, click Save File.
      Save inReach Sync Download in Firefox
    2. When the download finishes, the down arrow on your toolbar will appear blue Blue Down Arrow. Click the down arrow, then click the file name to open it.
      Open inReach Sync From Firefox Downloads
    Microsoft Edge Instructions
    When the downloaded finishes, it should display under the down arrow on your toolbar. Click the file name to open it.
    NOTE: If you do not see this, select ••• in the top right, then Downloads.
    Open inReach Sync from Microsoft Edge Downloads
  6. Follow onscreen prompts to complete installation.
Using inReach Sync for Windows
  1. Plug the inReach into the computer with the Garmin cable.
  2. Launch inReach Sync from the computer.
    inReach Sync Symbol
  3. Login when requested. Use the same email and password the device is associated with.
  4. inReach Sync will automatically detect your inReach and begin syncing.
    inReach Sync Program Determining Updates
  5. Close inReach Sync when the sync completes.
    inReach Sync Your inReach is Up to Date
inReach Sync for Mac
Current Version of inReach Sync for Mac: 1.5.510932
Installing inReach Sync for Mac
NOTE: inReach Sync for Mac is intended for Intel-based Mac computers. For Mac computers that use Apple silicon, installing Rosetta may enable the computer to use inReach Sync. For more details, see - Apple Support: If you need to install Rosetta on your Mac.
    NOTE: On Mac, the file should appear on your desktop
    Safari Instructions
    1. If prompted to allow downloads on explore.garmin.com, click Allow.
    2. Click the down arrow on your toolbar, then double-click the file name to open it.
      Open inReach Sync from Safari Downloads
    1. When prompted to save the file, click OK.
Using inReach Sync for Mac
    inReach Sync Symbol
    inReach Sync App Mac
    inReach Sync App Mac Up to Date
Related
