Planning Course Climbs in Garmin Connect
When creating a cycling course in your Garmin Connect™ account you can better prepare for climbs using map settings. To get started with creating a course, refer to Creating a Course in Garmin Connect.
Accessing Climbs
At any time during course creation, select the layers icon in the upper right to reveal the following menus:
Climb filters in Garmin Connect mobile and Garmin Connect web
Climb Map Legend
During course creation, climb icons climb icon of a mountain appear at the start of every categorized climb. Your map view identifies all categorized climbs available in your area with climb icons. Select the climb icon to see climb difficulty, average grade, distance, total ascent, percent paved and a detailed elevation chart.
Climb Difficulty Categories
Climb categories are calculated by: climb length (m) x climb average grade (%).
As you are creating a course, filter your map to show only the climb categories that are relevant to you. Use this tool to view only the climbs you are interested in riding, or the climbs you want to avoid.
climb difficulty slider from Easy to hard (HC)
Climbs within the same category will vary in length and grade. Within the same category, you will see both shorter and steeper climbs, as well as longer and flatter climbs.
NOTE: Climb categories do not consider altitude, grade variability or surface.
Easy (Uncategorized):
These are the flattest climbs. They will not take a significant effort compared to categorized climbs.
Category 4:
The easiest of the categorized climbs. At shorter distances, they are fairly flat and manageable (~3 km = 3-5% average grade). These climbs won’t get much longer than 5 km, and they will remain feeling relatively flat.
Category 3:
At shorter distances, these climbs are very difficult (~3 km = 10.5% average grade). They reach their max length at about 10 km. As they get closer to that length, they start to feel relatively flat (~3% grade). However, you will have to endure that grade for longer.
Category 2:
At shorter distances, these climbs will have very difficult to extreme grades (~3 km = 10.5-12% average grade). At a climb length of 10 km, you will have a 3-4% average grade. They reach their max length at ~16 km, with ~3% average grade.
Category 1:
Attempt these only with targeted training and experience. At shorter lengths, these climbs are extremely challenging grades to tackle (~3 km = 16% average grade). At longer lengths, you will still have grades difficult for almost all riders (~10 km = 5-6% average grade). It is possible to find these climbs as long as 20+ km.
Hors Catégorie (HC):
Translates to “Beyond Categorization”. These are the most difficult of all climbs. They are either the longest, the steepest or both. They are as tough to find as they are to complete. At shorter lengths, HC climbs will hit extreme grades (~5 km = 12.5% average grade). It will be difficult to find an HC climb shorter than 5 km, as the grade would get insurmountable. At longer distances (~10 km+), grades will be difficult and grueling. There’s no upper limit to the difficulty of HC climbs. They are found as long as 65.5 km+ with an average grade of ~6%.
About Climb Grade
A climb’s average grade is an average measure of how steep or flat the incline is over the entire length of that climb.
The feeling of difficulty of a climb is subjective. Perceived difficulty will change based on many variables (for example, rider fitness and ability, gearing, total distance of the climb, whether the ride is paved vs. unpaved, etc.).
Garmin Connect Climb Colors legend
Below is an example of a Category 3 Climb with a variety of grades:
Climb details including grade and length
Climb Grade Vs. Climb Category:
Climb grade is one factor in calculating a climb’s category. Both climb grade and climb category are measures of difficulty. However, climb category also considers the length of the climb. Climb category will give a slightly more complete picture of difficulty compared to climb grade.
Surface Type
Use the surface filter to only show climbs relevant to the kind of riding you are doing. Show only paved, only unpaved, or all types of terrain.
surface type filter in Garmin Connect web
Related
