Getting Started With the fēnix E Watch
If you are setting up a fēnix® E watch for the first time, the steps below will walk you through the process to set up and get the most out of your new watch. The video below will also walk you through the steps.
Setting up the fēnix E Watch
When powering on the watch for the first time, you will be prompted to configure your user setting and preferences on the watch. These settings can be changed at any time.
Power on the watch by holding Light (upper left) button.
Learn About the Touchscreen and Buttons
TOUCHSCREEN
Tap to choose an option in a menu.
Hold the watch face data to open the associated widget. NOTE: this feature is not available on all watch faces.
Swipe down on the watch face to view the notification center, or while on other screens, hold for 2 seconds before swiping down to view the notification center.
Swipe up on the watch face to scroll through the widget loop.
Swipe from left to right to return to the previous screen.
Cover the screen with your palm to return to the watch face and turn down the display brightness.
LIGHT (Upper Left) Button
Press to turn on the watch.
Press to wake or turn down the display.
Quickly press twice to turn on the flashlight.
Hold to view the controls menu.
UP/MENU (Middle Left) Button
Press view the notification center from the watch face.
Press to scroll up while in menus.
Hold to view the main menu.
DOWN (Lower Left) Button
Press to scroll through the widget glance loop and menus.
Hold to view the music controls from any screen.
START/STOP (Upper Right) Button
Press to view the activity list and start or stop an activity.
Press to choose an option in a menu.
BACK/LAP (Lower Right) Button
Press to return to the previous screen.
Press to record a lap, rest, or transition during a multisport activity.
Hold to view recently used apps.
Enabling and Disabling the Touchscreen
To temporarily enable or disable the touchscreen, hold DOWN (lower left) button and START (upper right) button.
To enable or disable the touchscreen during general use hold UP/MENU (middle left), select Watch Settings > Display & Brightness > Touch, and select an option.
Choose your language by scrolling through the list using UP/MENU (middle left) button and DOWN (lower left) button, press START (upper right) button to select the language.
Pair the watch to your smartphone with the Garmin Connect™ app (optional). NOTE: Pairing the watch with Garmin Connect will also register the watch.
Learn More About Bluetooth Pairing
Why pair to a phone? Pairing to a phone lets you easily sync data to a Garmin Connect account, gives you access to connected features like on-watch weather, smart notifications, and phone voice assistant integration, allows you access to safety features like incident detection and assistance alerts, and more.
Proceed through any onscreen prompts to select your preferences and user settings.
Set up the Activity Menu by selecting your favorites (optional).
Learn How to Set Your Favorite Activities
Press START (upper right) button to access the activity and apps menu.
Use UP/MENU (middle left) button and DOWN (lower left) button to scroll through the list of available activity types.
Press START (upper right) button to open the folder of a certain type of activity.
Press START (upper right)button to select each activity you wish to use.
Select Done when finished.
You can also pin your three most used activities to the top of your activity and apps menu.
From the watch face, press START (upper right) button.
Select Activities.
Scroll to the activity profile you want to pin.
Hold UP/MENU (middle left) button.
Select Pin Activity.
After setting up the watch, tips may pop up on the screen for the first day, which will give you further information about getting the most out of your watch. If you want to learn more about the watch, you can check out the Welcome to the fēnix E Watch or owner’s manual.
