Verifying Maps Installed on an Automotive Device
To Check the Map Version Loaded On Your device:
1. Touch Settings
2. Touch Map
3. Touch Info
4. Within this section, you will see all of the mapping loaded onto the device.
    • If there is no checkmark next to the map(s) listed, touch the box to add a check. This will enable the mapping on the device.
If the Map Info screen is inaccessible or blank, see Restoring Maps Missing or Deleted Off an Automotive Device.
Current Map Version: 2026.10 (North America) as of February 12, 2025.
See North America Map Regions to view map coverage for each region.
