What is the Dive Readiness Glance on My Garmin Dive Computer?
WARNING: The dive readiness feature calculates dive readiness scores based on a limited set of factors and does not measure whether or not it is safe for you to dive. It is the responsibility of the diver to judge their own dive readiness and to plan and conduct a dive safely. Failure to do so could result in an accident leading to serious personal injury or death.
The Dive Readiness glance on your compatible Garmin dive computer gives a score between 1-100 with an included short message that can help you determine how ready you are for a dive each day. For more information on Dive Readiness, see the Garmin Dive Science page.
To see if your watch supports the Dive Readiness glance, refer to your owner's manual and search "Dive Readiness."
What Contributes to Dive Readiness?
The score is continuously calculated and updated throughout the day using these factors:
Dive Readiness widget from watch
What Does My Score Mean?
Dive Readiness graph
Viewing Dive Readiness
Select one of the options below to learn how to view the Dive Readiness glance.
Garmin Dive App
  1. Open the Garmin Dive app.
  2. Select More.
  3. Select Dive Readiness.
  1. From the watch face, scroll down into the glance loop.
  2. Select Dive Readiness.
Adding the Dive Readiness Glance
Follow the below steps to add the Dive Readiness glance to your compatible Garmin dive computer.
  1. Press Middle left button.
  2. Scroll into the Settings.
  3. Select Appearance.
  4. Select Glances.
  5. Select +Add.
  6. Select Dive Readiness.
Dive Readiness will now show in the glance loop.
