(2013) Service Bulletin 1334: G1000 0321.23 System Software Update for Diamond DA40/DA40F Aircraft
PRODUCT AFFECTED
All G1000 WAAS-equipped Diamond DA40/DA40 F aircraft with system software version prior to 0321.23 (including the 0369.XX system software versions).
COMPLIANCE
Optional: STC Service Bulletin 1334 may be incorporated at the customer’s request.
DESCRIPTION
This Service Bulletin provides information required to update G1000-equipped Diamond DA40/DA40F aircraft to G1000 System Software Version 0321.23.
PURPOSE
This software update provides the following for all G1000 equipped Diamond DA 40/DA40F aircraft:
  • MFD Vertical Profile View
  • NAV Database synch capability
  • Standby NAV database capability
  • XM Weather Display Enhancements
  • Added WAAS approach capability for airports with 3-letter identifiers
  • AOPA Airport Directory Support
  • Added Range-To-Altitude Arc on MFD Navigation Map
  • Compatibility with Enhanced Search & Rescue Option
  • Re-establishes use of checklist capability
The following Garmin service documents are addressed by the installation of this software update:
  • Service Bulletin 1322 (GDL 69/69A improvements)
  • Service Advisory 1129 (Momentary Loss of GRS 77 and GDC 74A Functions)
  • Service Advisory 1101 (GDL 69/69A TFR Reporting Issue)
  • Service Advisory 1041 (GDL 69/69A NEXRA Weather Reporting Issue)
  • Service Advisory 0914 (Loss of Heading/Attitude Information Following Stall Maneuvers)
