Changing Map Unit Settings and Position Format on the Garmin Explore Website
The Garmin Explore™ website offers multiple unit and position format settings that can be customized to meet different needs. Changes to these settings will affect both the Map page at explore.garmin.com, as well as your MapShare™ page. You can find the available options and how to change them below.
Changing Map Unit Settings on Personal Accounts
  1. Log in at the Garmin Explore website.
  2. Select Account for personal accounts, or Settings for professional accounts.
  3. Select Units.
  4. Select an option from the dropdown list under the desired category.
  5. Select Save.
Changing Map Unit Settings on Professional inReach Accounts
  1. Log in as the administrator at the Garmin Explore website.
  2. Select Settings.
  3. Select Preferences.
  4. Select Edit next to Units.
  5. Select an option from the dropdown list under the desired category.
  6. Select Save.
Available Unit Settings on the Garmin Explore Website
Coordinate System
  • Decimal Degrees (WGS84)
  • Degree Minutes Seconds (WGS84)
  • Degree Minutes (WGS84)
  • UTM/UPS (WGS84)
  • USNG (NAD 83)
Measurement Units
  • Kilometers/Meters
  • Statute Miles/Feet
  • Nautical Miles/Feet
  • Nautical Miles/Meters
Related
