Steps to Edit 'Connections' in Garmin Connect
Garmin Connect allows you to share your activities and compete in online challenges with other users by managing Connections.
To add an individual to Connections using Garmin Connect Web:
Sign into Garmin Connect
Select Connections from the navigation bar on the left
Select
Input the Connect user's full name or username (case sensitive) in the search bar
Select Connect next to desired username
User will receive an add request and it should now have "Pending" next to their name
To remove an individual from Connections using Garmin Connect Web:
Select Connected next to the name of the connection you wish to remove
Select Disconnect
The connection has now been added or removed from Garmin Connect.
