Changing Parking Mode Settings in the Garmin Drive App
Note: Parking mode settings option will not display unless it detects a Parking Mode Cable attached to your Garmin Dash Cam.
When using your compatible Garmin Dash Cam with a Parking Mode Cable, the Garmin Drive™ app allows you to enable or disable Parking Mode or to change the length of time that it records.
To Change the Parking Mode Settings in the Garmin Drive app:
1. Open the Garmin Drive app
2. With your dash cam connected, touch the gear/wheel (settings) in the upper right corner
3. Select the Vehicle, then select the dash cam
4. Touch Parking Mode
5. Select the preferred settings
If the Parking Mode Cable is not attached, Parking Mode will not appear the Garmin Drive app settings as shown below:
- NOTE: Settings may vary with different Garmin dash cam models.
