Creating Detailed Routes for the Tread in BaseCamp
The BaseCamp™ software can be used to create a detailed route that the Garmin Explore™ app will navigate. This article will guide you through the steps.
First, Create a Track in BaseCamp and Convert it to a Route with the Steps Below:
  1. Open BaseCamp
  2. Select a location for the saved track
  3. Select Tools
  4. Select Track
    Note: The cursor will now appear as a pencil when hovering over the map.
  5. Use the pencil to:
    • To create a straight line between points: click a point on the map, then move the cursor and click another point
    • To draw a track with curves: left-click on your mouse on the map and drag the cursor along the path you would like to take
  6. Repeat step 5 to add to the track
  7. Right-click to save the track. The track will now appear as a gray line on the map.
    TIP: You can also press Esc on your keyboard to save the track.
Once the track is saved, convert the track into a route by selecting the appropriate link below for your operating system.
Windows -  BaseCamp - Creating a Route Based on a Track
Mac - BaseCamp - Creating a Route Based on a Track
Transfer the Route from BaseCamp:
After converting the track, find the new route in Library and send it to a microSD card or export it to use with your Garmin Explore app. Select the preferred method below:
See Transferring Data from BaseCamp to an Automotive Device or SD Memory Card for more information.
Exporting the Route to be Used With the Garmin Explore App:
Access the File on Your Device
Once this is done, select the preferred method below for accessing the file on your device:
Importing the GPX File to the Device from a microSD Card:
Tread® and Tread® - Base Edition GPS navigators: Importing GPX Files (Waypoints and Routes) from a microSD Card to the Tread.
Tread® - Overland Edition, Tread® XL - Overland Edition, Tread® - SXS Edition GPS navigators: Importing GPX Files (Waypoints and Routes) from a microSD Card to the Tread - SxS Edition, Tread - Overland Edition, and Tread XL - Overland Edition.
Importing the GPX File to the Garmin Explore Website:
