Creating a Route Using Route Planner on the GPSMAP 66, 67, or 86 Series
The GPSMAP® 66i, 66s, 66sr, 66st, 67, 67i, 86i, 86s, 86sc, and 86sci handhelds have a Route Planner feature that allows you to easily create routes using either direct paths between points or calculated routing to follow available roads and trails.
NOTE: If Route Planner is not a listed application on your device, it can be added to the main menu. For steps, see - Options Are Missing From the Main Menu on My Outdoor Handheld.
A route can include many waypoints, and it should include at least a starting point and one destination.
  1. Press MENU twice to access the main menu.
  2. Select Route Planner > Create Route > Select First Point.
  3. Select a category.
  4. Select the first point in the route.
  5. Select Use.
  6. Select Select Next Point to add additional points to the route.
  7. Select QUIT to save the route.
