Adding Shortcuts to a fēnix 8 Watch
The fēnix® 8 watches offer shortcut options which allows for the customization of buttons to quickly access specific settings or options on the watch. These shortcuts assign secondary functions to the watch buttons instead of needing to make the selections from the watch menus. To access the function programed as a shortcut, hold the specified button or button combination for two seconds. See the video below for more information:
Customizing the Shortcut Buttons for a fēnix 8 Watch
Hold UP/MENU (middle left button) to open the menu.
Select Watch Settings.
Select System.
Select Shortcuts.
Select the button you wish to assign a Shortcut.
Select the Shortcut option.
For a list of available Shortcuts and options, select an option below.
Available Buttons and Button Combinations
Your watch comes with some shortcuts preprogramed but you can customize what happens when you hold the following buttons or button combinations.
Hold START (upper right) button
Hold BACK (lower right) button
Hold DOWN (lower left) button
START + DOWN (upper right and lower left) buttons
START + UP (upper right and middle left) buttons
BACK + LIGHT (lower right and upper left) buttons
BACK + UP (lower right and middle left) buttons
Shortcut Options
None
ABC (Altimeter, Barometer, and Compass)
Alarm Clock
Baro. Watch Mode
Broadcast HR
Calendar
Change Sport
Clocks
Controls
Display (only available on fēnix® 8 - AMOLED Edition watches)
Display Settings
Do Not Disturb
Dual Grid
Flashlight
History
Lap
Lock/Unlock Device
Messenger
Metronome
MOB (Man Overboard)
Music
Navigation
Notifications
Phone
Phone Assistant
Pulse Ox
Recent Apps
Red Shift (only available on fēnix® 8 - AMOLED Edition watches)
