Garmin BlueChart Mobile Discontinued
The BlueChart Mobile application has been discontinued and is no longer updated. As an alternative, use either the ActiveCaptain application or the Navionics application.
If the vessel has a compatible Garmin chartplotter, we recommend using the ActiveCaptain application designed to be used with a Garmin chartplotter. More information about the ActiveCaptain application can be found here.
If the vessel does not have a compatible Garmin chartplotter, use the Navionics application. More information about the Navionics application can be found here.
For instructions for saving and transferring BlueChart Mobile data, see Related Content below.
Related
