Formatting a microSD card on the Garmin Dash Cam 30 and Garmin Dash Cam 35
It is recommended to format any new microSD card you choose to use in the Garmin Dash Cam. On some occasions, you may also wish to format a card that is already in use.
NOTE: Formatting a microSD card will delete all content, including protected or saved files. Ensure that you have removed all data you want to keep before proceeding with formatting the card.
To format a microSD card using the Garmin Dash Cam:
  1. Press the button next to the down arrow until Settings displays
  2. Press the button next to the check mark to select Settings
  3. Press the button next to the up or down arrow to highlight Setup
  4. Press the button next to the check mark to select Setup
  5. Press the button next to the up or down arrow to highlight Format Card
  6. Press the button next to the check mark to select Format Card
  7. Press the button next to the check mark after reading the warning message
  8. Press the button next to the up or down arrow to highlight Yes
  9. Press the button next to the check mark
The microSD card will now be formatted.
