What do I do if my Vehicle doesn’t have a Cigarette Outlet or 12-Volt Outlet?
Garmin automotive devices are designed to be plugged directly into a cigarette outlet or 12V outlet in a vehicle. Most vehicles will have a 12V outlet even if they don't have a cigarette outlet. Sometimes they are in unexpected places, so it is recommended to check the vehicle's owner's manual if it is not easily found.
If the vehicle does not have a cigarette outlet or a 12V outlet, some devices can be used with a USB cable or a third-party adapter, but they may not be able to provide enough power to charge the device or allow it to operate properly.
We recommend using at least a 2A rating for output voltage as some 1A rating for output accessories may not provide enough power to the device.
See the FAQs below for more information.
