Manually Entering and Saving Coordinates as a Waypoint on a Dakota Series
Coordinates for a specific location can be entered manually and saved by creating a waypoint and editing the location field.
Creating a Waypoint With Known Coordinates
- Navigate to the main menu.
- Touch Mark Waypoint.
- Touch Save and Edit.
- Touch Change Location.
- Use the highlighted arrows to select the character you would like to change.
- Use the number pad to select new numbers or use the arrows to select letters.
- Repeat steps 5 and 6 as necessary.
- Touch the green check mark.
- Touch the red X.
The coordinates will now be saved as a waypoint in the internal memory of the device.
