Showing Active Track Data on the Map Page
If you find the active track log not showing on the Map page, the track log recording method needs to be modified. To find the recording method setting:
From the main menu, select Setup.
Select Tracks.
Select Track Log.
Select Record, Show on Map.
If you wish to see the active track log on the map, but do not want to continue recording new tracks simply save the active track and then set this saved track to show on map.
Saving the Active Track
From the main menu, select Track Manager.
Select Current Track.
Select Save Track.
Enter a new name for the track if desired, otherwise the default name will be the date and time the track was recorded.
Select Done.
Setting a Saved Track to Show on the Map
Select a saved track.
Additional steps for archived tracks:
Select Archived Tracks.
Select the track you want to change.
Select Make Favorite.
Select the saved track.
Select Show on Map.
NOTE: If you only see Hide on Map, then the track is already set to display on the map.
