My Alpha 100 is Damaged and Needs to be Replaced
If your Alpha® 100 has become damaged (dropped, run over, etc.) and needs to be replaced, if you are within the United States you can use the link below to create an Return Material Authorization (RMA) to get your unit replaced.
You will need the Serial Number for your unit from inside the battery compartment.
Request replacement online here .
Related
