Estimated Body Temperature Data Field on a Garmin Device
Below are some FAQs on the Estimated Body Temperature Data Field from the Connect IQ™ store.
What Data Does This App Provide to Me?
This app is an experimental data field that will display estimated core body temperature based off heart rate during a physical activity. This is only an estimate of core body temperature.
What Devices Are Compatible With This?
For a complete list, select the Compatible Devices tab from the Connect IQ Store app
NOTE: Compatible Edge® cycling computers require the use of a separate heart rate sensor.
How Do I Install This to My Device?
For help with installing Connect IQ apps to most devices, see - How to Install Connect IQ Content Using the Connect IQ Store App.
NOTE: Edge® 820 and Edge® Explore 820 cycling computers must use the Garmin Connect™ app to install Connect IQ apps. For instructions, see - How to Install Connect IQ Content Using the Garmin Connect App.
How Do I See the Data Field on My Device?
In order to see this data field you must adjust your data field settings from an activity profile. Estimated Body Temperature will be listed under Connect IQ Fields for most devices.
For assistance on how to change a data field refer to your owner's manual.
