Why Am I Not Seeing Animated Workouts on My Garmin Watch?
Compatible Garmin® watches support animated videos for certain types of workouts. The videos will show proper form and movement for the workouts. If you are having trouble finding or viewing an animated workout, try the steps outlined below.
For watches that support animated workouts, and supported activity types, see - Garmin Connect: Using Animated Workouts on a Watch.
Viewing the Animated Workout
Animated workouts will show during active periods of workouts, not during rest periods. You may see the animated workouts screen automatically during the active period of some workouts, otherwise you may need to scroll through your data screens to find the animation.
Update Software
It is important to make sure your watch has the latest software version. You can use Garmin Express™ to make sure your software is up to date.
Using Garmin Express to Update Your Watch's Software.
Animated Workouts Are Not Enabled
Workout videos need to be enabled to be viewed. Generally, the setting for enabling workout videos will be in the watch's settings for the activity type being done. To make sure you have animated workouts enabled, refer to your owner's manual.
Example
WorkoutVideosSetting
NOTE: Image taken from a fēnix® 6 Pro. Settings will vary by watch.
Workouts Not Being Sent to the Watch
If you are not able to receive new workouts, or are seeing an error message that you have exceeded the maximum number of workouts, you may need to delete some workouts on the watch to make space. Here is how to delete a workout on the watch.
  1. Press START to access the Activity Menu.
  2. Select the activity you wish to delete a workout from.
  3. Hold UP.
  4. Select Training.
  5. Select Workouts.
  6. Select a workout.
  7. Select Delete.
  8. Select Yes.
