(2018) Service Bulletin 1860 Rev B: Approval of GTN v6.50, Flight Stream 210 v2.90, Flight Stream 510 v2.40, and GTN COM v2.30 software for AML STC SA02019SE-D Rev B
REVISION B:
Added EASA STC 10037574
PRODUCTS AFFECTED:
GTN 6XX/7XX navigators and Flight Stream 210/510 installed using Approved Model List (AML) Supplemental Type Certificate (STC) SA02019SE-D are affected.
CERTIFICATION APPROVAL:
STC SA02019SE-D and EASA STC 10037574 MDL Revision 19 (or later FAA-approved version)
COMPLIANCE:
Optional
PURPOSE:
AML STC SA02019SE-D and EASA STC 10037574 Master Drawing List (MDL) (005-00533-C0, Rev.19 or later FAA-approved version) includes software updates for the GTN 6XX/7XX, Flight Stream 210, and Flight Stream 510, as specified in the Aviation Service Document Notification (ASDN) linked below.
GTN 6XX/7XX software updates include the following changes:
  • Increased the maximum search-and-rescue orbit pattern radius from 10 NM to 100 NM.
  • Added support for outputting primary flight instrument data to portable devices through the Flight Stream 510.
  • Added support for terrain alerting function including aural and visual alerts and callouts.
  • …And many more…..
