Select the following link to download the app: Connect IQ app for Amazon Music.
Select
button.
If prompted, sign into your Garmin® account.
Select your watch to download the app.
Acknowledge any app permission requests.
- A message should indicate that the app will be installed during the next sync. If this does not occur automatically, sync your watch manually:
- To sync via Bluetooth: Be in range of your paired smartphone, and open the Garmin Connect app. Select
on the My Day page to sync.
- To sync via Wi-Fi: Be in range of your Wi-Fi network, and hold the Menu button on the watch. Scroll down and select Wi-Fi; if you do not see Wi-Fi listed, you may need to select Settings or Connectivity first and then select Wi-Fi. Select Wi-Fi Sync or Connect to Wi-Fi and wait while the watch connects to Wi-Fi and syncs.
- To sync using Garmin Express™ software: Connect the watch to a computer using the supplied power/data cable. Open the Garmin Express program. A sync will automatically occur once the watch is detected.
