The M1 can be connected to an NMEA 2000 network to enable AIS and Navigation data, including GPS to be sent to other NMEA 2000 devices. An NMEA 2000 drop cable and T connector are required to connect the M1 to a vessel’s NMEA 2000 network. If modification needs to be done to the Instance or System Identification, this can be done via the Cortex Onboard™ App or from the H1 handset.
- Select Menu (
- Select Settings
- Select Device Settings
- Select Networks
- Select NMEA 2000...
- Select Device Instance (0-255) (select to enter value)
- Select System Instance (0-255) (select to enter value)
- Select Main Menu (
- Press the wrench icon (
) to open the Configuration Menu.
- Select Networks
- Select N2000 (NMEA 2000)
To change the Device or System instance select the field and use the touchscreen menu to key a number between 0-255
