Charging Alpha LTE Collar
Charge the Collar
You should fully charge the battery before you use the Alpha® LTE dog tracking collar for the first time. Charging a fully depleted battery takes about five hours.
  • The Alpha LTE dog tracking collar has a USB C charging clip that you will attach to the dog device by lining the gold pins up with the silver charging contacts.
  • The LED turns solid red while charging, and solid green when fully charged.
  • When the LED turns solid green remove the charging clip from the collar.
