Calibrating the eTrex Touch 35/t Barometric Altimeter
With proper calibration, barometric altimeters will report elevations ranging from -2,000 to 30,000 feet within +/- 50 feet1. The barometric altimeter may calculate values beyond 30,000 feet, but these values may not be accurate.
Always calibrate the altimeter outdoors with a clear view of the sky.
Calibrating the eTrex® Touch 35 or eTrex® Touch 35t Outdoor Handhelds
  1. Open the Main Menu
  2. Touch Setup
  3. Touch Altimeter
  4. Touch Calibrate Altimeter
  5. Follow the onscreen prompts to complete calibration
Note: Garmin's outdoor devices are designed as recreational GPS devices, as an aid to navigation. They should not be used for any activity requiring precise measurements, such as surveying or weather prediction.
While calibrating to a known elevation can be accurate to +/-50 feet, calibration by GPS is accurate to +/-400 feet.
For more information on barometric altimeter accuracy and proper calibration, see the Related FAQ.
Related
