Customization Options for Garmin Instinct Crossover Series Watch Face
The Instinct Crossover series offers eleven pre-loaded watch faces. Additionally, each watch face has the ability to customize what data or symbols to display. The selected watch face may change what can be customized, what options are available, or how the data appears. Depending on the watch face, you will have one to five data customization options.
The instructions below are for customizing the pre-loaded watch faces. For instructions on customizing watch faces that have been downloaded from the Connect IQ Store, see - How to Customize a Watch Face Through Connect IQ Store
Customizing the Watch Face
  1. From the watch face, hold UP/MENU.
  2. Select Watch Face.
  3. Press UP/MENU or DOWN/ABC to preview the watch face options.
  4. Press GPS to select the desired watch face:
    • To activate the watch face, select Apply.
    • To customize the data that appears on the watch face, select Customize.
      1. Press UP or DOWN to preview the options.
      2. Press GPS to apply.
      3. Complete for all available data fields until you see a check in the dial screen.
Available Watch Faces
The Instinct Crossover offers eleven pre-loaded watch faces with different customizable data fields for each watch face. The physical hands are not shown in the screenshots of the watch faces below in order to provide an unobstructed view of the watch face.
 CrossoverWatchFace_1Graph with Three Fields Watch Face
Has one customizable graph field, and three additional data fields. Day of the week and date field is preset.
CrossoverWatchFace_2 Digital Time Watch Face
Has two customizable data fields. Time and day of week fields are preset.
CrossoverWatchFace_3Contours Watch Face
Has five customizable data fields.
CrossoverWatchFace_4Graph and Box Watch Face
Has one customizable graph field, and three customizable data fields.
CrossoverWatchFace_5Gauges Watch Face
Has one customizable graph field; two gauge fields which can display seconds, battery percentage, percentage daily step goal, percentage daily floors climbed goal, or percentage weekly intensity minutes goal; and one customizable data field which includes a custom day of the week gauge in addition to the other data options.
CrossoverWatchFace_6Analog Watch Face
Has one customizable data field.
CrossoverWatchFace_7
Digital Time Background Watch Face
Shows the current time in the background dots. Has one customizable data field.
CrossoverWatchFace_8Seconds Background Watch Face
Shows the seconds in the background dots which will disappear if the watch is stationary. Has one customizable data field.
CrossoverWatchFace_9Sun or Moon Position and Graph Watch Face
Includes customizable Sun position or Moon position gauge, and one customizable graph field.
CrossoverWatchFace_10aAlternate Time Zone Watch Face
Displays Local or UTC time and has two customizable data fields.
CrossoverWatchFace_11Diagonal Watch Face
Has one customizable data field, and digital time can be shown or hidden.
Watch Face Data Field Options
The following data icon options are available on most of the watch faces. Sometimes the configuration is different, but the symbols can help you identify what the field is showing.
 BatteryIconBattery Life
Displays the remaining battery life.
TimeIcon Time
Displays the current time in digital format.
DayDateIconWeekday and Day
Displays the current calendar date and day of the week.
MonthDateIconDay and Month
Displays the current calendar date and month.
HeartRateIconHeart Rate
Displays the reading taken from the optical heart rate sensor (OHR).
OHR sensor must be on to get a reading.
StepsIconSteps
Displays daily step count.
ElevationIcon
Elevation
Displays your current elevation.
BarometerIconBarometer Reading
Will display the current barometer pressure (default unit is millibars).
SunsetIconSunset/Sunrise
Displays Sunset/Sunrise time.
NotificationIconNotifications
Displays the number of notifications.
Notifications number won't be cleared until they are cleared from the phone.
CalendarIconCrossoverCalendar Notifications
Displays the time of the next upcoming event on your calendar
WeatherIcon
Weather
Displays the weather information received from the Garmin Connect App.
CaloriesIconCalories Burned
Displays total calories burned for the day.
FloorsIconFloors Climbed
Displays floors climbed for that day.
IntensityMinutesIconIntensity Minutes
Displays the number of intensity minutes generated for the week.
UTCIconUniversal Time Coordinated
Displays Universal Time Coordinated (UTC).
UTC is the successor to Greenwich Mean Time (GMT).
SolarIcon
Solar Intensity1
Displays current solar intensity as a percentage.
1Solar data only available on watches with solar charging.
Graph Data Field Options
Several watch faces offer a graph data field.
CrossoverBarometer
Barometer Graph
Displays current barometric pressure and graph showing the change of barometric readings over the last four hours.
CrossoverElevation
Elevation Graph
Displays current elevation and graph showing the change of elevation readings over the last four hours.
CrossoverHeartRate
Heart Rate Graph
Displays current heart rate in beats per minute and graph showing heart rate readings over the last four hours.
CrossoverSolarGraph
Solar Graph1
Displays graph of changes in solar intensity over the last six hours.
For more information on customizing the Garmin Instinct Crossover series, refer to the Owner's Manual. The video below also gives an overview of customizing the watch face, as well as customizing the widget glance loop, on your Instinct Crossover series watch.
