Setting Up the Alternate Time Zone Widget Glance on Garmin Watches
The Alternate Time Zones widget or glance on your compatible outdoor watch allows you to see what time it is in other time zones around the world.
If you have not added the Alternate Time Zones widget or glance to your watch yet, refer to your owner's manual for specific steps on customizing the widget or glance loop.
Setting Up Alternate Time Zones
NOTE: The following are general steps that should work for most watches. For more specific information, see “Adding Alternate Time Zones” in your owner's manual.
Navigate to the Alternate Time Zones widget or glance.
Select the Alt. Time Zones widget glance.
Select Add Alt. Time Zone or Add.
Select a time zone to add.
Edit the time zone information.
Press START/STOP (upper right button) to confirm.
On watches with Aviation features, you can also use the four letter International Civil Aviation Organization (ICAO) airport identifier code to set up an alternate time zone.
