Setting Up My Tread GPS Navigator to Track My Dogs
The following guide shows how to set up your Tread® GPS navigator, Tread® - Base Edition GPS navigator, Tread Textron, and Tread 2 series with a compatible dog tracking handheld so you can track your dogs on the larger Tread navigator screen.
Setting Up the Tread GPS Navigator and Dog Tracking Handheld
See the detailed video below for instructions.
These steps work with the Alpha® 10, Alpha 100, Alpha 200, Alpha 200 Plus, Alpha 300, Astro® 320, Astro 430, Astro 900, and PRO 550 Plus dog tracking handhelds along with the Tread, Tread - Base Edition, Tread Textron, and Tread 2 series.
On the Tread Navigator
  1. Select Apps.
  2. Select Dog Tracking
Troubleshooting Your Systems
Enable Broadcast or Remote View on your Dog Tracking Handheld
NOTE: Ensure other broadcasting devices are powered off.
Alpha® 100
  1. Select Set Up.
  2. Select Dogs.
  3. Select Broadcast Dog Data.
  4. Select Enable.
Alpha® 10
  1. Select Set Up.
  2. Select Remote View.
  3. Select Status.
Alpha® 200, Alpha® 200 Plus, and Alpha® 300
  1. Select Set Up.
  2. Select System.
  3. Toggle on Broadcast Dog Data.
Astro®
  1. Select Set Up.
  2. Select Dogs.
  4. Select Enable.
Pro 550 Plus
The Pro 550 Plus uses ANT+ to share dog locations to your compatible outdoor watch and broadcast dog data by default. No other steps are required on the handheld. Ensure your handheld is up to date on the latest software.
Related
