Changing Device Settings in the Garmin Connect App
You can use the Garmin Connect™ app to adjust settings on your compatible Garmin® watch or bike computer. The app connects to your device using Bluetooth® to instantly update things like display options, sounds and alerts, and data screens.
For features not available in the app, check your owner's manual for instructions on how to change those settings directly on your device.
Compatible Device List
  • Approach® S50 watch
  • Approach® S70 | Approach® S70 - TaylorMade® Edition watches
  • D2™ Mach 1 | D2™ Mach 1 Pro watches
  • Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition watches
  • Descent™ G2 watch
  • Descent™ Mk3 | Descent™ Mk3i watches
  • Edge® 540 |Edge® 540 Solar cycling computers
  • Edge® 550 cycling computer
  • Edge® 840 | Edge® 840 Solar cycling computers
  • Edge® 850 cycling computer
  • Edge® 1040 | Edge® 1040 Solar cycling computers
  • Edge® 1050 cycling computer
  • Edge® Explore 2 cycling computer
  • Edge® MTB cycling computer
  • Enduro™ 2 watch
  • Enduro™ 3 watch
  • epix™ (Gen 2) | epix™ (Gen 2) Sapphire | epix™ (Gen 2) Porsche Edition watches
  • epix™ Pro (Gen 2) Standard | epix™ Pro (Gen 2) Sapphire watches
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition watches
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition watches
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition watches
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition watches
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition watches
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition watches
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition watches
  • fēnix® 8 Pro - AMOLED | fēnix® 8 Pro - MicroLED Edition
  • fēnix® E watch
  • Forerunner® 165 | Forerunner® 165 Music watches
  • Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music watches
  • Forerunner® 265 | Forerunner® 265S watches
  • Forerunner® 570 watch
  • Forerunner® 945 | Forerunner® 945 LTE watches
  • Forerunner® 955 | Forerunner® 955 Solar watches
  • Forerunner® 965 watch
  • Forerunner® 970 watch
  • Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition watches
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition watches
  • Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition watches
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition watches
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition watches
  • Instinct® 3 - AMOLED | Instinct® 3 - Solar watches
  • Instinct® 3 Tactical Edition - AMOLED | Instinct® 3 Tactical Edition - Solar watches
  • Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition watches
  • Instinct® Crossover AMOLED | Instinct® Crossover AMOLED - Tactical Edition
  • Instinct® E watch
  • Lily® 2 | Lily® 2 Classic | Lily® 2 Active watches
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2) watches
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition watches
  • quatix® 7 Pro | quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7 - Solar Edition watches
  • tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® - Pro Ballistics Edition watches
  • tactix® 8 - AMOLED | tactix® 8 - Solar watches
  • Venu® Sq 2 | Venu® Sq 2 - Music Edition watches
  • Venu® 3 | Venu® 3S watches
  • Venu® 4
  • Venu® X1 watch
  • vívoactive® 5 watch
  • vívomove® Trend watch
  • vívosmart® 5 watch
  • vívoactive® 6 watch
Changing Device and User Settings in Garmin Connect App
NOTE: Some settings can only be changed directly on the Garmin device, in which case you may receive an "Update Setting on Device" prompt.
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Garmin Devices.
  4. If you have more than one device, select the device you would like to make changes to.
  5. Select an option to edit (such as User Profile to set heart rate zones, or Activities & Apps to change data fields for activities).
  6. Make the desired changes.
  7. The changes will be reflected immediately on the device.
Video Tutorial
Real Time Setting Changes via the Garmin Connect App
Related
