Push Distance is Inaccurate in Wheelchair Mode
If the distance recorded by a wheelchair mode capable device is inaccurate, you can set a custom push stroke length in your Garmin Connect™ account to calibrate the device to your push stroke length. Choose your phone type below to reveal instructions.
Android
  1. Open the Garmin Connect app.
  2. Access the menu by selecting More (bottom right).
  3. Select Settings
  4. Select User Settings
  5. Enable Custom for Walking Stride Length.
  6. Enter a known distance.
  7. Enter the number of pushes needed to cover that distance in the Total Steps field.
iOS
  3. Select Settings
  5. Select Custom Stride Length.
  6. Enable Walking
  7. Enter a known distance.
  8. Enter the number of pushes needed to cover that distance in the Total Steps field.
