Print the Map and Route Directions in BaseCamp
BaseCamp™ software will allow printing the turn by turn directions of a route on both PC and Mac versions.
Not all maps are printable. Some mapping license agreements restrict the option to print.
To Print a Route in BaseCamp Software:
Windows:
- Choose the Pan or Select tool
- Double-click the route to print
- Click Print in the lower right and a print setup box will appear
- Click Page Setup
- Check mark the box next to Route Directions
- Click OK
- Click Print to print a copy of the map and turn-by-turn directions
Mac OS X:
- Choose the Selector or Hand tool
- Choose the Print tab in the box that appears
- Select Print Directions or Print Map
Once the print option has been selected, both the maps and directions of the selected route will be printed.
To get a Simplified Waypoint by Waypoint List, Set the Route's Profile to 'Direct':
Windows:
- Double-click the route to select it.
- To the right of the route's name, change the profile to 'direct'. The route will recalculate.
- Click Page Setup
- Click OK
- Click Print to print a copy of the map and turn-by-turn directions.
Mac OS X:
- Double-click the route to select it, a box with the route's information will open
- In the upper right hand corner of the box, select the route's activity being used
- Change the route's activity to 'direct'. The route will recalculate.
- Click Print in the route information box
NOTE: Routes set to 'direct' will create a straight line route between points. This allows Basecamp to print the route as a list of Waypoints instead of directions.
