Access Navionics Charts and Features on Marcum MX-7GPS Plotters
Plotter Software
IMPORTANT: Plotter manufacturer’s latest software updates required.
Check your plotter’s software by pressing the MENU button and select SYSTEM SETTINGS. Version will be listed in the lower-right corner.
Current chart plotter/sounder software update versions
NOTE: Do not use your Navionics® card to update your plotter software or have it in your plotter when you update.
Chart Layers
SonarChart™ OFF = Nautical Chart – official charting detail
SonarChart ON = SonarChart – high-definition bottom contour detail
Go to Menu > GPS Map > Settings > SonarChart
Details (All)
Depth Contours (All)
Dynamic Icons (On/Off) - Tides/Currents
Easy View (On/Off) - Text and icon magnifying feature
[Navionics] Community Edits (On/Off)
Transparency: 0 = Full Overlay (harder to see chart details) or 100 = Less Overlay (harder to see overlay details)
Menu > GPS Map > Settings > 2D/3D
Allows for a three-dimensional view of water contours with the ability to pan and rotate the chart information at different angles.
Menu > GPS Map > Advanced
SonarChart Density – density of contours displayed on SonarChart layer
Fishing Range – select a range of depths to fill with a different color
Shallow Water – highlights shallow water between 0 and up to 10m/30ft
- Go to Menu > GPS Map > Settings
- SonarChart (On); Depth Contours (ALL)
- Go to Menu > GPS Map > Advanced
- Select Sonar Log > Record
Transparency – 0 = Full Overlay (harder to see chart details) or 100 = Less Overlay (harder to see overlay details)
Minimum Depth – All contour lines up to that depth will display
SonarChart Live Tide Correction – Allows contours to be adjusted according to nearest tide station (coastal marine waters)
