When using the Tacx Training™ app or the Tacx Training™ Desktop app, a ride can only be recorded by following a workout or course. These applications do not allow you to record a "free ride" by simply pressing start then riding. A simple alternative would be to follow a manual slope or power workout.
Slope and Power workouts are simple workout options that allow you to set a specific grade % of a climb or wattage, respectively, where the trainer matches the set resistance. This number can be adjusted manually at any time during the workout using + / - buttons within the workout dashboard.
Open the Tacx Training app.
Pair your Tacx smart trainer under Settings > Device Manager.
Return to the Dashboard on the app.
Select either Power to choose a specific wattage to use or Slope to choose a specific Grade % of a climb to use.
Increase or decrease the values by using the - or + buttons.
Select Start Now to begin your workout.
You can adjust the setting during the workout by selecting the - or + again, as needed.
Once finished, select Stop and then Save to record the workout to your account.
