1. Touch Apps
2. Touch Trip Planner
3. Touch the Plus
4. Touch Select Start Location.
NOTE: The Start Location is the first stop on the route. You can use your current location as the starting location, but it isn't necessary. The device will skip your current location if that is where you are when it begins to navigate.
5. Locate a starting point using the search options
6. Touch Select
7. Touch the Plus to add a second point
8. Follow steps 5 through 7 to locate and add up to 30 total points
- To adjust the order of points as you add them, touch and hold on the point you'd like to move, then drag it to the desired location on the list
- Touch
to remove a point
- Then touch Delete
9. Touch Next when all desired points have been added
10. Type a name for the route and touch Done. The device will now calculate.
The route is saved to the Trip Planner automatically
Touch Go! to proceed with navigation.
