Use of Non-Garmin Antenna on Dog Tracking Handhelds
Use only the supplied antenna or a Garmin recommended antenna accessory. Unauthorized antennas, modifications, or attachments could permanently damage the radio1 and may violate FCC regulations. Warning: Do not use any radio that has a damaged antenna because if it comes into contact with your skin, a minor burn can result.
These products may be used only on specific radio frequencies which vary depending on the country of use. The handheld device and the dog device allow the user to install a different antenna. Changing the antenna can result in improved radio performance and higher radiated power. You must not use the device with a third part antenna or an antenna not approved by Garmin. Go to www.garmin.com/tracking-legal for details about the performance and radio frequency of this product, lawful accessories, and power limits for countries.
1Damage caused through the use of a non-Garmin antenna is not covered under warranty.
Related
