Using the Manage Maps Feature in Garmin Express for a dezl Device
Wi-Fi updates are recommended for the dezl LGV/OTR610, dezl LGV/OTR710, dezl LGV/OTR810, dezl LGV/OTR1010, and dezlCam LGV/OTR710.
dezl LGV/OTR610, dezl LGV/OTR710, and dezlCam LGV/OTR710: See Wireless Map and Software Update Instructions for instructions.
dezl LGV/OTR810 and dezl LGV/OTR1010: See Wireless Map and Software Update Instructions for instructions.
You can also manage your maps in Garmin Express.
- Garmin Express can be used to move mapping to a memory card
- The Wi-Fi feature cannot be used for this process
To Manage Maps in Garmin Express:
1. Open Garmin Express and select your device
- See How Do I Install Garmin Express? if you haven't installed Garmin Express
- See Adding and Removing Devices in Garmin Express for instructions to add your device to Garmin Express
2. Click Manage Maps
3. Select any map regions you want installed on your device
NOTE: Do not uninstall any mapping required to remain on the device. Removing City Navigator maps would make the device unable to route. Use the Manage Maps feature to reinstall your map if you accidentally removed your City Navigator map.
- Check marks indicate maps currently installed on your device
- Click View to see the map coverage for a region
- The bar at the bottom will show the amount of free space remaining on your device
- You will see the free space decrease as you as choose mapping to add
4. You can also install mapping to a memory card if your device is low on space
- Click the Removable Storage tab and select your map
5. Click Move
6. Click Apply Changes once you have chosen the mapping you want to add
7. Review the Terms and Conditions and click Accept if prompted
8. Click Continue
