Edge Explore 2 Battery Life Expectations
The battery life of your Edge device may be impacted by the usage of features within the product or the manner in which it is used.  The information in the tables below is presented to help outline the conditions used to determine the estimated battery life specification.  The additional usage of these features or other features not included below may result in reduced battery life.  The information presented below is presented as a general guide for reference only on the Edge Explore 2 products.
Use Case DescriptionBattery SaverDemanding
GPS SettingGPSMulti-GNSS
Data Recording IntervalSmartSmart
Number of Paired Sensors24
ANT Sensor TypeSpeed, CadenceSpeed, Cadence, Heart Rate, Power
Phone Paired & ConnectedYesYes
LiveTrack EnabledYesYes
Backlight Brightness30%60%
Backlight TimeoutStays On1Stays on
User Interface ConfigurationData PageMap Page
Following a Course2YesYes
Operating Temperature Range10C-40C10C-40C
Estimated Battery LifeUp to 24 hoursUp to 16 hours
1Battery Saver Backlight
The backlight brightness and timeout settings will automatically change when users enable Battery Saver. The default backlight brightness level 60% will be changed to 30% after enabling Battery Saver. Users may change the backlight brightness even after enabling Battery Saver. Users may change the backlight timeout through System->Display. Setting the brightness level higher than 30% may result in a reduction in battery life.
2Following a Course
Each course is unique in regard to the number and type of alerts generated.  The number of alerts generated by the course will impact battery life. Courses that generate a large number or frequent alerts will consume more battery life than courses with fewer turns or alerts.
