My Approach G3 or G5 Is Not Recognized by the Computer
Mass storage devices appear as a drive on your computer allowing for easy access to data on the device regardless of the operating system. Occasionally, your Approach® G3 or G5 golf handheld may not appear as a drive. To troubleshoot an Approach device that is not being recognized by the computer, try the following.
Checking the Connection With the Computer
- Try a different USB port.
- Do not connect through a USB Hub.
- Try a different data transfer USB cable.
Forcing the Data Connection With the Computer
If the Approach is still not recognized after one minute, these steps can be tried.
- Disconnect the Approach from the computer.
- Power off the Approach (if powered on).
- Press and hold the Power button.
- Plug the Approach into computer.
- Wait until device is recognized by computer.
NOTE: It may take up to 30 seconds for device to be recognized as a drive. - If prompted, install USB device drivers.
- Release the Power button.
Your device should now function normally.
