There are three locations in the Garmin Explore app where the Import GPX File feature can be accessed.
When the GPX file is imported, a new Collection is created with the name of the GPX file containing all of its data.
If you have GPX files for courses, routes, tracks, or waypoints that you would like to use with one of the following GPSMAP® outdoor handhelds, these files can be used by uploading them to Garmin Explore™ and then syncing them to the handheld.
GPSMAP 66i | GPSMAP 66s | GPSMAP 66sr | GPSMAP 66st
GPSMAP 67 | GPSMAP 67i
GPSMAP 86i | GPSMAP 86s | GPSMAP 86sc | GPSMAP 86sci
GPX files can be uploaded by using the Garmin Explore app, or by visiting the Garmin Explore website.
Before you can sync new data to the handheld, you must first pair it with the Garmin Explore app on a mobile device. For pairing instructions, see - Pairing a GPSMAP Series Handheld With a Phone or Tablet.
When the Garmin Explore app is opened or refreshed, it automatically syncs between the Garmin Explore website and the paired handheld when it is powered on. It can take a few moments for both to complete.
Syncs can also be performed manually with the steps below.
Ensure the same account is logged into on the Garmin Explore app that is also used on the Garmin Explore website.
The paired mobile device needs a data connection to sync to and from the Garmin Explore website and you must agree to allow Garmin to receive and store your data. For more details, see - Data Is Not Syncing From the Garmin Explore App to the Garmin Explore Website.
To sync to and from the Garmin Explore app, the handheld needs to be powered on and in range (about 10ft) of the paired mobile device.
Open the Garmin Explore app.
Select the profile icon in the top left.
Select
below the user's name and email address.
The sync icon has to be orange to manually perform a sync. If the icon is gray, this usually indicates a recent or upcoming sync.
Wait for the sync to complete.
When the sync is finished, the icon will change to gray and display the time of the last sync.
Select
Devices.
Select the device you wish to sync.
Select ![]()
The Garmin Explore app will update the time of the last sync after the sync has completed.
After syncing the handheld, the newly added data can be found by accessing one of the navigation options.
Press FIND.
Select Waypoints, Tracks, Courses, or Routes.
Select a waypoint, track, course, or route and select Go.
Newly added data can also be found in the main menu under Waypoint Manager, Track Manager, Course Planner, or Route Planner.
