Change Unit of Temperature and Distance on an Automotive Device
The unit of temperature displayed on your device will depend on the temperature scale used by the Country your device is set to. Changing the unit of measure for distance will also change the unit of measure for temperature. Choosing kilometers will change the temperature to Celsius and miles will change the temperature to Fahrenheit.
NOTE: Changing the text language can impact the unit of temperature the device uses. See Changing the Text Language on an Automotive Device if you can't Read it to change the text language.
To Change the Unit of Measure for Distance:
- Touch Settings
- Touch Map Display
- Touch Units
- Select the desired unit of measure
The unit of measure and temperature will now be changed.
NOTE: The unit of measure will not automatically change. It must be manually changed.
