Changing an inReach Device Address
Your inReach® satellite communicator's address is automatically generated by the email address used when initially creating your inReach account. For more information, see Related at the bottom of the page.
When you change the email address within your account using the steps below, the inReach address may also change as a result. Confirm that all of your inReach contacts have the correct inReach device address.
Due to this and the inReach Consumer Terms and Conditions, it is not recommended to allow others to change your inReach account information when lending out your inReach device. For more information, see - Borrowing or Lending Out an inReach Handheld.
NOTE: Your account email address can only be changed to an email address that is not already in the Garmin system. Your inReach address will be listed as inReach Addr. on the Garmin Explore™ website under Account > My Info.
Log into the Garmin Explore website.
Select the Account page.
Select Edit next to your name under the My Info tab.
Change the email address under the Email box.
Select Done.
If the inReach Address changed at this point, you should see that change reflected on your inReach device after syncing.
Sync your inReach handheld. Refer to the links below for your device.
Alpha® 200i - Syncing an Alpha 200i or 300i With the Garmin Explore Website and App
GPSMAP® 66i, 86i, or 86sci - Syncing a GPSMAP 66i/86i/86sci With the Garmin Explore Website and App
GPSMAP® 67i - Syncing a GPSMAP 67i With the Garmin Explore Website and App
inReach Messenger or inReach Messenger Plus - Simply connect it with the Garmin Messenger™ app on a smartphone. Any account related changes will automatically be synced to the inReach device when it is connected and the phone has a data connection. For steps, see - Pairing an inReach Messenger With a Smartphone or Pairing an inReach Messenger Plus With the Garmin Messenger App.
inReach Mini, inReach SE®, inReach Explorer®, inReach SE+, or inReach Explorer+ - Updating inReach Firmware and Syncing Account Changes with inReach Sync
inReach Mini 2 - Syncing the inReach Mini 2 With the Garmin Explore Website and App
Montana® 700i or 750i - Syncing a Montana 700i/750i With the Garmin Explore Website and App
- Montana® 710i or 760i - Syncing a Montana 710i/760i With the Garmin Explore Website and App
