How do I fly to a set of coordinates?
There are a couple of ways to fly to a set of latitude and longitude coordinates. The easiest way to get close is to start on the map page and then activate the cursor by moving the toggle pad. When this is done a border will appear at the top that will show the latitude and longitude of the cursor. Once you get the cursor to the position you want press the 'Direct to' button and the GPS will navigate you to that point. If you have the exact latitude and longitude you can create a user waypoint and then change the latitude and longitude so that you can navigate to that waypoint.
