Using the BarkLimiter Feature on Your System
BarkLimiter™ technology detects bark signals through vibration and movement from the dog's throat and/or head. This greatly reduces the chance of false corrections from external vibrations such as paw scratching and scraping against external surfaces like floor tile, water bowls, or dog tags. Your pet will not receive false corrections from the barking of a nearby dog, other dogs in the neighborhood, the kennel, or doggy daycare.
Training Features
Collars that support the BarkLimiter function have various training features depending on the system. The three training features are Autorise, vibrate, and a set stimulation level.
Autorise
Autorise
Autorise Bark correction is a standard feature of many Garmin BarkLimiter dog devices. The Autorise mode is designed to automatically increase the electronic stimulation to the correct level that limits excessive barking. All devices that have an Autorise bark correction feature have a panic guard.
  • When a dog barks, it will be corrected with electronic stimulation (no warning tone or vibration).
    NOTE: There can be a few free barks allowed before the system starts correcting.
  • It will deliver only one correction every 3-5 seconds to give the dog a chance to respond.
  • If the dog continues to bark, the level automatically increases every four seconds reaching the highest stimulation level within 30 seconds.
    • The highest level of stimulation will vary by device.
  • Two to five minutes after the dog stops barking, the system will reduce the stimulation to half of what previously stopped the dog.
    • If the dog starts barking again, it starts from that lower level and increases as the dog continues to bark.
    • This ensures the dog is corrected at the right level more quickly the next time.
  • Should the dog refrain from barking completely, the device will slowly decrease the stimulation level reaching the lowest level within 30 minutes.
  • When the device is turned off, the level is reset to the lowest level.
Panic Guard
If the collar is unable to stop the barking behavior after 30-40 seconds at the highest level of stimulation, the collar will go into Panic Guard. This will stop all correction for 2 minutes to allow the dog time to calm down. The panic guard timer will reset if any bark is detecting in the 2 minutes. No barks are corrected while in panic guard. Panic guard is only enabled when using Autorise.
NOTE: Panic Guard does not work for set stimulation level correction or the vibrate correction; this is only a feature built-in with Autorise.
Vibrate
Vibrate
Vibrate is a standard feature on many Garmin bark-limiting dog devices. The Vibrate mode is designed to automatically vibrate as a correction when the dog barks. This correction is applied once every 2-5 seconds with continuous barking.
Set Stimulation Level
On bark correction collars, you can set a stimulation level that the dog will be corrected at when it barks. The highest level for bark correction will vary by device. When using the set stimulation level the dog will be corrected once every 3-5 seconds through continuous barking until the barking stops. The highest level of stimulation will vary by device.
Training Handheld and Collars with BarkLimiter Features
Pro 550
The BarkLimiter features for the Pro 550 are set only through the dog collar. The only option for the BarkLimiter feature for the Pro 550 system is Autorise.
Enabling BarkLimiter
Press and hold the power button until the LED light turns blue, then release the power button.
Disabling BarkLimiter
Press the power button to turn off the collar.
Pro 70
The BarkLimiter features for the Pro 70 are set only through the dog collar. The only option for the BarkLimiter feature for the Pro 70 system is Autorise.
Press and hold the power button until the LED light turns blue, once blue release the power button.
Pro TrashBreaker™
Delta Sport™ XC and Delta Upland™ XC
The Delta Sport XC and Delta Upland XC have the BarkLimiter feature that you are able to use directly from the handheld only. Both the Delta Sport XC and Delta upland XC have three BarkLimiter correction features: Autorise, Vibrate and Set Stimulation.
Enabling BarkLimiter Mode
  1. Press and release the upper left key on the handheld.
  2. Select one of the three possible modes:
    • Training only mode - This indicated by no dog head seen on the LCD screen.
    • BarkLimiter mode - This is indicated by a dog head on the LCD screen but no training mode options.
    • BarkLimiter mode and training mode - This is indicated by a dog head on the LCD screen as well as training mode option.
NOTE: When the dog's barking head appears on the LCD display, the status LED on the dog collar flashes three times - the device enters BarkLimiter only mode. See Delta Dog Device Status LED Lights for more information
Adjusting the BarkLimiter Settings
Once BarkLimiter is enabled, you can change the correction intensity level, or set it to vibrate or Autorise by pressing the up or down arrow keys on the top right of the handheld.
  • Select the U to set for vibration by using the Up or Down arrow keys.
  • Select A to set for Autorise by using the Up or Down arrow keys.
  • Select a number (1-18) to set the correction level by using the Up or Down arrow keys.
Using BarkLimiter Mode and Training Mode Simultaneously
When both BarkLimiter mode is active and training mode is active, both the dog barking head icon is showing on the screen and well as the other training commands such as T, C, M or V. When the training mode is active the intensity levels may be changed by pressing the up or down arrow keys. The intensity level changes only apply to the training mode level, not the BarkLimiter mode.
Adjusting Only the BarkLimiter Intensity Level While Using the Training Features
  1. Turn off training mode, press and release the upper left key on the handheld until only the dog’s barking head icon is showing.
  2. Choose what level or setting you want for the BarkLimiter correction.
  3. Switch back to BarkLimiter mode and Training mode by making sure both the dog's barking head icon is showing as well as the training commands BarkLimiter settings will be retained.
Sport® Pro
The Sport Pro system has BarkLimiter features available to be used from the handheld as well as the dog collar. The Sport Pro has three BarkLimiter correction features: Autorise, vibrate, and set stimulation.
Enable BarkLimiter Mode From the Handheld
Autorise
  1. Set the intensity dial to AUX.
  2. Press the BarkLimiter On button.
    The green LED flashes on the collar.
  3. Press BarkLimiter On button again to enable Autorise.
    A blue LED light on the dog collar indicates that it is set.
Set Intensity to Set Level
  2. Select BarkLimiter On button
    The LED flashes green on the collar.
  3. While the LED is flashing green on the collar, rotate the intensity dial to the intensity level you want.
  4. Press the BarkLimiter On button again
Set BarkLimiter Mode to Vibrate
  2. Press BarkLimiter On button
  3. Press the VIBE button.
    A blue LED light on the collar indicates that it is in BarkLimiter mode.
The BarkLimiter will now correct the dog with vibration only.
Disable BarkLimiter Mode From the Handheld
  • If quick stimulation is needed when your dog collar is in BarkLimiter mode, you can override the BarkLimiter feature using the handheld by holding one of the training keys for four seconds.
  • The dog collar returns to training mode. BarkLimiter mode may be disabled by setting the dial to AUX and selecting BarkLimiter Off key.
  • Power off the dog collar.
BarkLimiter Deluxe
For more information, see - BarkLimiter Deluxe Bark Correction Features.
BarkLimiter 2
The BarkLimiter features for this collar are controlled and adjusted through the Garmin Canine app on a smartphone. This app allows the settings on the collar to be adjusted. For steps, see - Using BarkLimiter Setting with Canine Application.
BarkLimiter 2VT
The only training options on the BarkLimiter are vibrate and tone. This is set through the Garmin Canine app on a smartphone. This app allows the settings on the collar to be adjusted . For steps, see - Using BarkLimiter Setting with Canine Application.
PT 10, PT 6, TB 10
Autorise is the only feature available to be set directly from the dog collar.
Press and hold the power button until the LED light turns blue.
Training Handhelds and Collars Without BarkLimiter Features
  • Alpha® Series
  • Astro® Series
  • TT™ 15 / TT™ 15 mini
  • T5 /T5 mini
  • Delta Sport
  • Delta
  • Delta SE
  • Delta XC
  • Delta/Delta Sport Dog Device
  • PT 5
