Install multiple maps to a single Garmin device with MapSource
Multiple maps can be easily loaded onto the same compatible Garmin device using MapSource® mapping software.
To send multiple maps:
- Click on the map regions to send from the first map using the Map Tool
- Click map products drop down box and switch to the next map
- Click on the map regions to send from this map using the Map Tool
- Repeat this process until all desired map sets are selected
- Click Transfer
- Click Send to Device..
- Verify the device you are wishing to send to is in the device box
- Click Send
This will allow multiple map sets to the Garmin device.
