Getting Started With Tracking on an inReach SE
Your inReach SE® handheld can track your progress throughout your trip. When you turn on Tracking, the inReach® handheld will send tracking points at intervals over time. While tracking information is not stored on the inReach SE handheld to review, it can be used with LiveTrack™ tracking or MapShare™ tracking to record and share your adventures.
IMPORTANT: With the Safety,1 Essential, and Enabled plans, there is an additional cost per point (varies by currency) using the Moving interval. As an example, if your Moving interval is set to 10 minutes and you had tracking on for 1 hour, you could be charged for 7 track points (this includes a starting track point). For more details, see - Understanding Charges for Tracking on inReach Safety, Essential, and Enabled Plans.
Starting Tracking With the inReach SE Handheld
From the home screen, select Tracking.
Select Start Tracking.
On the Tracking screen, you will be able to monitor the number of points sent, the time tracking began, and the most recent time a point was sent. At any time you can turn off tracking by selecting Stop Tracking.
Others can view your track points and follow along with your trip progress by visiting your tracking page. Select Send a Tracking Link below for steps on sharing your track.
Sending a Tracking Link
Use Share to send friends and family a link to either your LiveTrack or MapShare page from the inReach handheld, depending on which you have enabled on your account. Just a like a regular message, select recipients, add message text, and send. Garmin will automatically include a link (and include the MapShare password if you set one in the Garmin Explore website) to your tracking page in the email or text message that your recipient receives.
Select Share:
When prompted select Share again.
Select the To Field to add recipients to send the link to. If you have MapShare enabled on your account, a MapShare link will be included in the message. If you have LiveTrack enabled on your account, a LiveTrack link will be included in the message. Adding more text to the message is optional.
Select Send.
Changing the Moving Interval
Moving Interval determines how often the inReach SE will send track points with your current GPS position, elevation, speed, and heading to either your LiveTrack or MapShare page, depending on which you have enabled on your account. These are referred to as Tracking Points in the inReach Subscription Plan details.
Select Settings.
Select Tracking.
Select Moving Interval.
Select the desired Moving Interval setting.
1The Safety subscription plan is no longer available for purchase. The Safety plan has been replaced by the Essential plan.
