My Approach S10 is in the Wrong Language
If your Approach® S10 golf watch is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the watch, follow the steps for resetting the device.
Changing the Language
  1. From the clock screen, press OK
  2. Press Down 1 time
  3. Press OK
  4. Press Down 3 times
  5. Press OK
  6. Press Down until you see your language
  7. Press OK
You have now changed the language on your Approach S10 watch.
If you were unable to change the language on your watch using the steps above, select the option for Factory Reset below and follow those steps to reset your watch. You will be prompted to select a language after the reset, during initial setup.
Factory Reset
  1. Power off the unit by holding Up for 3 seconds and then press OK
  2. Press and hold Back and OK
  3. Press Up until the Garmin logo appears on the screen
  4. Continue holding Back and OK for 10 seconds
  5. Release OK
  6. 5 seconds after releasing OK release Back
Note: Any scorecards saved to the watch will remain on the watch after a factory reset.
